carringb
Jul 10, 2019Explorer
Here's the main reason I'd avoid the 4500 for now: Service
This truck being a joint venture, will have some parts designed and/or supplied by Navistar that won't be in the regular GM pipeline. Or might not be covered in the GM repair guides yet. And GM has a history of rolling out other joint venture vehicles without having enough techs trained initially.
Ford was formerly in the same boat with the F650, before pulling it away from Navistar. Getting work done wasn't always a pleasant experience, and Oregon only has one dealer certified to work on the "Blue Diamond" (the joint venture name) F650/750 trucks.
Also, it probably won't ride as well, since the 3500 likely has a much stiffer frame, especially torsionally. While the MDT frame are strong, they tend to be a little floppy so you feel more judder.
44,066 PostsLatest Activity: Apr 16, 2026
