Devo_the_dog
Nov 21, 2020Explorer
DougA wrote:
So there you have it... get a bigger truck or bigger gas tank in the current one?
If money isn't a concern, shop around and decide which manufacture you like best. Then order the truck you want. Keep in mind, delivery times are much longer due to the Corona.
If you don't want to buy a new truck to replace a truck that's only 1 year old, put in the larger fuel tank. The added weight from the fuel will only be 107 lbs and you are still a few hundred pounds under payload capacity.
