Grit_dog
Dec 09, 2020Trailblazer
^Thanks for the suggestion. No, no coolant smell in the exhaust.
And I’ve seen it drip (only a couple times in months) up front near the radiator.
I’m fairly certain it’s the radiator. Been through radiator is on 2 separate SRT8s now and it’s fairly common.
Although the shop mentioned they’ve seen some water pumps too, (talking about the Charger not the truck). Although I’m certain that would be a constant issue.
Also no oil in coolant or vice versa and no residual combustion pressure in cooling system. It’s an external leak. Like I said, have seen it on the ground before, only a couple times. Rest of the time there’s no evidence of leak.
This issue is a known problem on some of these cars and it’s where the plastic tank is crimped to the radiator core. I suspect, it’s similar to the egr cooler you mentioned in that it doesn’t “always” open up. The old car eventually had some residue evidence once it got worse and had been happening a long time. I used to put a cup of 2 of coolant in every oil change.
No crustys built up yet that I could find on the radiator. But it’s also rainy time here again, so everything gets washed pretty good under there even despite the plastic cover under the radiator.
