Grit_dog's avatar
Grit_dog
Trailblazer
Dec 06, 2020
Shout out to Enumclaw Dodge....for the Wet Side Mopar owners
Since there’s a fair number of folks from around here, figured I’d post my GOOD experience with the service dept at Enumclaw Dodge dealer.
Took both the 2016 truck and 2016 car in for some recall and warranty work.
Truck is out of warranty and deleted, but the PO never had any recalls done, specifically the water pump.
Scheduled in easy, very accommodating. Zero issue with them doing recalls on a “modified” rig. Told them do not flash the ecm for anything. They understood. I declined the drag link “recall” (welding the lock nuts....), no problem. They did all the other recalls no problem.
Car only has a couple weeks left of the 3/36 warranty and is slowly loosing coolant again. It’s not evident where and only small amount and likely the radiator. Known issue with these cars. But I mainly wanted to get it documented lest it get worse in the near future after warranty is up. I explained this. They pressure tested, test drove. Confirmed they couldn’t find leak and actually said now this is documented in case you have issues with the radiator in the future it will be covered.
Good service is hard to come by sometimes, and this place is one of the good ones!
  • We used to have an awesome GM dealer close by both for sales and service until it was bought up by a local mega chain. I went in for a recall two weeks after the change and before the truck was out of the writer bay they were pushing wiper blades and scabin air filter to the tune of $110, both of which were almost new.
    Hopefully the one you found remains that way.
  • Thanks for sharing. I always went to Tom Matson, used to know many of the guys in back. Don't know anyone now that is owned by Bub Clary.
