Old-Biscuit
Mar 17, 2017Explorer III
djgarcia wrote:
2. when showering, turn on both the shore line water and the trailer water pump at he same time.
Only ONE will supply water
If city water pressure is higher then pump start set point pump will not run
If pump runs then it's discharge pressure will close check valve in city water connection
AS to OPs question
Shower has a flow resistor in it.
Either in end of hose or in shower handle
Some can be removed.
Some have to be 'enlarged'......just use a 1/4" drill bit
Without them higher flow rate
Aerators on end of faucets have them also. They can easily be removed
Some folks change out to an Oxygenics Shower Head.
Mixes air/water for feeling of increased flow
