- HannibalExplorerI had to seal up the glass door shower in our previous KZ Jag 5th wheel. It was leaking slightly around the same area. Good tip!
- BizmarksMomExplorerI have been having the exact same problem. I thought I was sloppy with the shower curtain until this last trip, when I was really careful, and it still happened. Thank you for posting this!
- TooTall2Explorer
poppin_fresh wrote:
My hybrid did the exact same thing! I thought the toilet was leaking until I realized that the water was coming from the shower seam if the camper was not PERFECTLY level.
I just squirted a small caulk dam along the side to divert water back into the tub and the problem was solved.
Yea, I bet there's a lot of folks having this same issue. Bad design. Anything to divert the water would work. - poppin_freshExplorerMy hybrid did the exact same thing! I thought the toilet was leaking until I realized that the water was coming from the shower seam if the camper was not PERFECTLY level.
44,056 PostsLatest Activity: Jan 12, 2020
