Eric_Lisa
Sep 07, 2015Explorer II
Howdy Kayteg1! I love your idea. I blatantly copied your project in my Lance truck camper.
I found the faucet from a place called "Duda Energy". Prompt shipping, a little over $100.
I did not use the handheld wand or feed line which came with it. The handheld does not have the on/off like the stock camper one does, and I thought the metal line would bang on and wear the side of the shower stall while traveling.
I did have to drill out the hole ever so slightly. I took my hole saw and cut a hole in a piece of scrap wood. I used that to center it over the existing hole since I could not utilize the pilot bit. It was really close already. I tool off maybe 1/16" all the way around. I could have done it with a file for what it was worth.
After the initial install and test I was disappointed as I couldn't figure out the temp controls. The faucet came with a cool schematic, but no install instructions. I looked at the schematic and realized the hot & cold are not the way I thought they would be, so I switched the lines. Simple solutions are the best. :)
As you can see from the picture, I have a loop on the wall which holds the handheld feed line. I could have made it work, but the angle would have pinched the line a bit. You would think the local Ace hardware would have a 1/2" 90 degree M-F fitting, but nope! Amazon to the rescue - $11 and they even delivered it on Labor Day. Not that bad, considering Ace wanted $8 for a stainless F-F elbow which I needed to add a $3 1" M-M fitting.
I tried to put in the included backflow devices. One went in no problem. The 2nd leaked no matter what I did. I gave up and took it out. Yes, I did install the included rubber screen washers.
I have never worked with the PEX plumbing lines before. The 'Sharkbite' fittings are actually pretty slick. All I had to do was cut the PEX line and square it up. There is probably an expensive tool for that, but I just used a utility knife. Then I used a handy grinding stone to file the end nice and even. The fittings just press fit on the PEX and are leak free.
The only other problem I had was the shower fitting on the new faucet assembly. I took it to Ace and could not find anything that would take more than one turn of threads. Finally I looked closely at the fitting. The threads were only partially cut! Starting about 2nd turns in they got flat on top, not sharp like normal threads. So I did buy a fitting from Ace which I oiled and used to work back and forth on the fitting until the threads cut in. I got three turns out of it, and some teflon tape sealed it up fine. No worries if it drips a bit as this fitting will only be under pressure when the valve is turned and the shower head is off.
I found the soap pump on Amazon for $20. The bottle does rub up against the black drain pipe a bit. It is a plastic bottle, so it has some give. Easy to fill as the pump just lifts out from the top. I thought it would be a kludge to fill the bottle and install it, but that is not how it is designed. Leave it alone once it is in.
Aside from including directions, the only other thing that would make this better is a swap out ring to change it over to Fahrenheit. I understand the Celsius numbers, but I would rather not have to do the conversion in my head. I guess I will just have to remember that 36-38 = a nice temperature.
Thanks again Kayteg1 for the inspiration!
-Eric
-Eric
44,071 PostsLatest Activity: Aug 30, 2026
