anutami
May 16, 2016Explorer III
Thanks for the info on this, I tried to tag along, but having issues. Here is my experience.
Spout came damaged when received.
Seller shipped me the shower hose for replacement (wrong part)
Seller then shipped me an entire new assembly so swapped out the spout
Both spouts were leaking at multiple locations
Spout has a wierd brass piece and several o rings
Removed brass piece to find one of the o-rings defective
The second spout also had the same problem.
Fixed the leak on the top half but still getting small drips on the bottom connection. Any ideas how to fix? There are 3 o rings that seal and I also used pipe dope.
Was a bit tricky getting everything installed because northwood doesn't give you any access panels in the wet bath. All the access is through the wardrobe and I also had to remove my oven to gain access to my water lines.
44,071 PostsLatest Activity: Aug 30, 2026
