Trackrig
Aug 16, 2014Explorer II
I used the kit when I installed a pressure tank. I used it since I was in there working on the water system and I needed some additional hoses, so I bought the kit. Between the pressure tank, the hoses and adding extra rubber between feet of the pump and where it was mounted, I now have a very quiet water system.
If you're going to be in there installing the hose kit, you should install the pressure tank since you'll have most of the fittings undone anyways.
Bill
Bill
44,056 PostsLatest Activity: May 04, 2014
