ScottG wrote:
Our new TT came with the Shureflow 4008. It's a nice pump woth good flow. Noise is not bad at all.
Seems like most of the time noise is more a factor of how the pump was installed.
Rubber mounting and using pipe insulation on any piping that makes contact with any other surface does a lot.
Yes - this is what I did in both our trailer and our B. I got the one in the trailer so quiet we can hardly hear it - which can be a problem if the o-ring in one of the low point drains goes bad and you don't know that all your water is being pumped out on the ground!
