dlr33
Mar 05, 2014Explorer
Sierra, Silverado, Avalanche, Yukon corroded brake lines
I've seen lots of postings on various truck forums about corroding exploding brake line on GM trucks, but I don't think the issue has been mentioned here. My 2005 Sierra treated us to a variation on 'pedal to the metal' last week when the brakes failed completely and with no warning at all. Fortunately we were not towing our fifth wheel at the time. NHTSA has an open 'investigation' into 1999 - 2003 models but may expand up to 2009 as more reports come in. So far no recall has been issued. It is worth a few minutes to climb underneath your truck and inspect the brake lines - mine was spraying brake fluid over the underside of the hood on the driver's side. There is a Technical Service Bulletin, which can be found with a little careful Googling, #13-05-22-001: it advises dealers that GM has made up kits of pre-formed and pre-flared brake lines, and that should dramatically reduce the cost of the repair from the $2,000 some dealers have been charging for manually working up replacement brake lines. Mine is still at the dealer, but when I get it back, hopefully repaired, I will add my note to the NHTSA site. GM refers to the dual-circuit braking system that should allow the vehicle to stop safely if one side fails: they neglect to mention what happens when both sides fail at once like mine did. Dangerous situation.
