northshore wrote:
Now as i remove this and replace the caulking we will see if what ever i choose to caulk with holds up.
Lately I've been using caulk that I had left from James Hardie siding job.
It is pretty affordable (I remember $3-4), you can shape it with finger, or plastic spoon and than you can still press it down following day. I start using it on my camper and seems to hold better than $8 painters caulks.
It is design to withstand UV and exterior use (unlike silicone).
You can order it in several colors at Home Depot, but minimum is 12 tubes case.
