gserveExplorerMay 02, 2015Silicone greaseWhat do you use on the "o" ring on the water filter housing? The manufacturer says to use silicone grease. What kind do you use?
gserveExplorerMay 02, 2015The plumbers grease I've seen say not for use on synthetic or rubber " o" rings
Related ContentGrease vs siliconeAnything other than silicone..Grease gun/ grease recommendationsSilicon grease on dump hose connections?Silicone
