gserveExplorerMay 02, 2015Silicone greaseWhat do you use on the "o" ring on the water filter housing? The manufacturer says to use silicone grease. What kind do you use?
westendExplorerMay 02, 2015I used to use vaseline but it stretched the ring too much. I started using mineral oil and that has worked well.
Related ContentGrease vs siliconeAnything other than silicone..Grease gun/ grease recommendationsSilicon grease on dump hose connections?Silicone
