Grit_dog
Aug 06, 2013Navigator III
Or heat 'em up CAREFULLY with a heat gun or propane torch. Use a hair dryer if you're uncertain as it wont get hot enough to burn the paint like a heat gun or torch.
Then scrub the glue residue off with some lacquer thinner or acetone.
OR get a 3M eraser wheel and just erase them off the truck with your drill. WOrks pretty good, very little glue residue cleanup usually.
44,056 PostsLatest Activity: May 04, 2014
