bwc wrote:
Is there such a thing as a manual 12VDC battery disconnect switch that will separate the truck from the camper when parked but will allow 12V for the camper. Most if not all that I see do not allow any 12V to camper when turned off. If not would the Sure Power 1314 be another choice? I am happy with current charge rate, just want to keep truck and camper separated when parked. Also, would the Sure Power be installed in line of the camper's positive battery wires, 12V in and then 12V out along with a ground or does it need to be installed on the charge wire in the camper? Thanks.
You can use a simple switch to turn the charge line on/off as long as the switch is rated for the max. current of the charge line . It also helps if the switch is lighted as a reminder that is on or off .
I use a combination of a continuous duty solenoid and a lighted switch to energize the solenoid . The switch is located in the truck dash , it seems more convenient than in the camper .
