trail-explorer wrote:
Kidoo wrote:
Wires are connected to camper using lift type connectors.
What is a "lift type" connector?
Lift Gate ConnectorThis connector is about the same size as the standard 7-pole round RV connector, but can handle 4 or 6 gauge wire at 200 amps. I would recommend using at least 6 gauge wire if you expect to get a decent rate of charge to the camper battery. You will probably be surprised how long the wires will be once you start running them if you take them all the way from the alternator to the camper.
