TerrorismIsn_tOExplorerNov 07, 2018Simple passive solar water heaterHey, I made a simple solar water heater with a 55 gallon barrel elevated slightly. Took a garden hose connected to a well and made a connection for the rather cold water on the bottom, the barrel i...Show More
Swell1ExplorerNov 07, 2018How about putting a 12 volt pump in line. Let the barrel gravity flow to the pump and let the pump build your pressure.
Related ContentPassive SteerAtwood water heater problemSimple RVing recipesSimple Heater "Fix"Replace insulation inside heater column.
