TerrorismIsn_tOExplorerNov 07, 2018Simple passive solar water heaterHey, I made a simple solar water heater with a 55 gallon barrel elevated slightly. Took a garden hose connected to a well and made a connection for the rather cold water on the bottom, the barrel i...Show More
beemerphile1ExplorerNov 07, 2018You don't need to pressurize the barrel. Use the pump in your RV to suck the water from the barrel.
Related ContentPassive SteerAtwood water heater problemSimple RVing recipesSimple Heater "Fix"Replace insulation inside heater column.
