ttavasc
Jan 31, 2017Explorer II
We have about 10K miles on our single axle trailer and no issues using an Andersen No-Sway hitch. Overall length is about 22 feet. Most of those miles are longer trips. Always ensure that you have sufficient tongue weight. I like to have at least 12% or more of loaded trailer weight. I also have the hitch adjusted so that the trailer is just slightly nose-down. It tows nicely and no issues at all with wind or semi's passing. Best cruising speed is about 62mph.
One of the requirements I had when looking at the single axle trailers was an uplifted tire rating. Ours came with LT LR-C tires. Keep them at max sidewall pressure and check frequently along with hub temps when running long distances.
I do think that the single axle is more trouble backing up - it turns much quicker than a dual axle which took a bit to get used to. Overall though we're pretty pleased with the whole setup.
