trailernoviceExplorerJan 29, 2019Single black/gray drain outletOur last tt (2016 crossroads zinger) had two separate gray tanks with two separate drains..so, at dump station, it would be - connect / drain/ disconnect, and then do it again at the second drain.. al...Show More
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problemWinterizing black and gray tanks
