mgirardo
Feb 02, 2019Explorer
bpounds wrote:
But if you use a drive-through dump station it means jockeying the trailer to dump a second time. I wouldn't like it either.
On our TT with 2 sewer outlets, the front outlet is just feet from our sewer connection in the ground. The rear is about 16 feet away. The front sewer hose is 10 ft, the rear is 20 ft they connect to a wye that is on the sewer connection in the ground.
If we were at a dump station, I wouldn't use the wye. I'd setup the front with the 10 foot hose and dump. While the front is emptying, I'd connect the 20 foot hose to the rear. When the front is done, disconnect it front the dump station and connect the rear. I'd pack up the front while dumping the rear. No jockeying of TT necessary.
-Michael
