Ive got a new F350 with an impressive tow capacity. The slide in is only like 1800 pounds I think. Its a 6 footer in an 8 foot bed. The truck is overkill for what im doing.
I measured the door. Its 22" wide. I think I can make the fridge fit as it ships, but if needed thought I may pull the door off the fridge. I am considering it however, so thank you for the heads up.
The camper IS set up for a fridge. Gas, 12 volt and 110 are all there. As well as both the wall and roof vent cutouts in the framing. Cutting the siding, installing shrouds and fridge, and that should be it so long as I can get it through the door.
The only things Im trying to determine are, did they come with a super small fridge (20 by 21 ish) or do I need to cut the upper cabinet out and install a (29 by 21 ish). Im guessing the larger fridge, as the small one is like 1.7 CF where the larger is closer to 3. Tiger4x4 was super helpful with some info. I believe SP used a norcold fridge, so that narrows it down a little, not that brand matters........... But I dont or cant find a super small norcold unit. Just Dometic.
