wmoses
Jun 11, 2014Explorer
marcsbigfoot20b27 wrote:
This is also where insulation, dual pane windows or not, and trailer construction come into play.
In 90 degrees full sunlight with 75% humidity on the beach I can run my 13.5 on my 27 ft trailer down to 65 degrees or lower with no problem. This is probably because my trailer is very insulated.
If your trailer quality is lower the AC may have a hard time keeping up with the heat bleeding back in. In that case parking in the shade should help.
You forgot slide outs. Your RV has R8 insulation all round (mine has: R-7 Walls, R-12 Floor, R-14 Ceiling) but mine has 3 slide outs so there is more surface area. Also my windows are single pane.
So it is not a question of lower quality, just different construction features.
44,070 PostsLatest Activity: Jul 25, 2026
