Fire19's avatar
Fire19
Size of Garage door
I am building a pole barn to store my fifth wheel and other toys My contractor states that a 14'x14' would do what I need. My current Fifth Wheel measured at the top of the air conditioner to the ground is 12'6". My question do any manufacturers build taller than 13'?
Thanks
  • philh's avatar
    philh
    Explorer III
    As stated, slope can make it insufficient height.
  • My door is 14’ high x 20’ wide and it works fine.
    It has been several years since I built but Wayne Dalton made my door and opener. I believe it is commercial because of the size.
  • The height of the door can also come into play depending on the slope of the driveway. If the approach is a steep angle you will need more room at the door.
  • If the door is actually 14' x 14' that is a good size, my 5er is 13'4" and most states have a 13'6" maximum height (without a permit).
  • A rollup or accordian door can be any height, but they get pricy.
    Understand that a 14' tall opening does not equal 14' of clear access.
    The average overhead door when open will hang down anywhere from 6" to a foot or more below the top of the framed opening.
    Your 14' door should be fine with a 12'6" trailer, but you must watch to ensure it is staying up as far as possible.
    You may even want to cut a piece of tubing such as the lightweight tubing used for a tv antenna mount to something like 13'6"" and use that to ensure the bottom of the door is always above your highest point before backing in.
