manualman
Sep 27, 2016Explorer II
An invertor is a device that takes DC battery voltage as a power source and creates AC line voltage for conventional outlets. Few to no RVs ever came with one, though lots of folks add them as convenience modifications.
You may be referring to the converter that does the opposite: converts AC line voltage into 12V DC. All RVs come with one of those and they do go bad sometimes. Check the fuse box for bad fuses before giving up. Replacements can be had for reasonable money on Ebay or Amazon. WFCO seems to be the most economical replacement. A popup won't need more than a 30 amp unit.
