dcb17b
Sep 28, 2016Explorer II
Is the upholstery thicker than the old stuff? If you can't push the beds in all the way try some dry or silicone lube on the slides. Make sure they are clean and there is no debris in the channel. There should(might) be some adjustment to the tie down latches. The one I had many years ago you could lengthen the latch by turning it(like a turnbuckle). I certainly would be very wary of towing it not having the top latched,they do fly off going down the road.
