We just picked up our first travel trailer and were a bit concerned about getting it in our driveway. Our driveway it pretty steep, narrow (<9' wide and cut into a hill), and we need to turn off of a...
Adding wheels at the back: - Eats up the clearance you are already short on. - Puts odd stress on the trailer frame. - Definetly need to be rated for a lot of weight. If loaded wieght of the trailer is 6000lbs, you probably need more like 1500# per wheel capacity. - If the rubber tires lose all their weight, it actually puts a lot of weight on the truck hitch. You could easily be putting 2-3000lbs on the hitch.
