ssthrd
Apr 24, 2021Explorer
On my 2013 2750RL, the cable arrangement is like this., and can be seen above the slide if it is partially open.
Just wondering if your slide is pulling even top-to-bottom and side-to-side. Does it look level both ways when it is fully extended? When out all the way, and standing outside, the bottom cables should have a bit of slack. could be the gear on top of the motor is skipping a tooth because too much slack in the chain.(see video).
I'm not too bad with a wrench, and I have adjusted mine. It's a real pain to do because the top face trim of the slide needs to come off (inside) unless you have extra long arms.
Anyway, that's a start. Good luck.
44,071 PostsLatest Activity: Aug 30, 2026
