On my 2008 Komfort TT I'm starting to get a worn spot on the floor where the leading edge of the slide floor stops when in. Has anyone seen this before and found a solution?
Slide Slickers will cure the symptom and keep the floor from getting scarred until you can get the slide adjusted. And maybe after that. Some slides simply cannot be adjusted to clear the floor and the ceiling at the same time (can we say "bad design"?)
