Has it always been like this, or did something happen to cause the misalignment? Yes, there are adjustments to correct this, but not all slide mechanisms are the same. Sometimes when a correction is made, it changes another area of adjustment, which then needs further adjusting. There are videos, and manufacturer service manuals on line, showing how to do this. If you have a mobile repairman available, it may be the best option. He could make the proper correction, and give you a little education, as to the process.
Mine has an adjustment for this on one end, but then further adjustment may be needed for both ends to go in/out a little farther before stopping.
Jerry
