gocamping14's avatar
gocamping14
slide out cable issue
have a primetime tracer with a rear lounge slide, about 10'. one of the top return cables,(total of 4 on unit, 2 top and 2 bottom) is totally slack and while the slide returns to the closed position, it is not working correctly. is this worth removing some slide covers to have a look or take it to the dealer. thanks for any assistance........ss
  • thanks for the suggestions. after removing 3 pieces of internal trim, I got to the cable system. one of the end nuts had vibrated off. after loosening a cable, was able to return system to good working condition. I nicely screwed the trim back into place, as over time these cables will need to be checked and or adjusted. now I can gain easy access to the whole cable system. rv units really should have been assembled in this fasion.
  • When you get it adjusted like you want it, put another nut on it to lock it in place.
  • They are easy enough to adjust, most are a threaded rod on the end of the cable, with a nut for adjustment. On mine they are marked as to where they go. Not sure if there is some kind of procedure to follow
    or not, I tightened it some, put in slide, checked the cables, then tightened it till it felt good
