brulaz
Apr 29, 2015Explorer
BurbMan wrote:
I believe that it was because of water running down the side of the slide when extended and then because there was no drip edge, it would run underneath the slide floor and found its way into the edge of the OSB floor.
None of these slides have a drip edge along the lower edge of their side walls, so it's not a question of whether they will leak, but rather a question of when....
The edge of the OSB board was exposed? That's bad. Or does the side wall cover the edge?
On mine the side wall does not cover the edge of the floor, but sits on top. I've had trouble with improperly installed drip rails not fully covering the edge of the plywood floor, or even draining water within the drip rail to the inside of the trailer. But at least there was a drip rail, and they tried ...:R
