Ldduck's avatar
Ldduck
Slide out info
Hello I hello new to the forum. I have been camping for 15 years. The camper I camped in for 15 years was a pop up. However now I just purchased a travel trailer with a slide out. It is a Coleman 29 qbh. I never owned a travel trailer with a slide out. Do you guys have any tips or information on how to maintain the slide out. Any info will be appreciated thanks
  • Welcome to the forum!
    There are several different types of slide out systems. Mine is rack and pinion, and requires very little maintenance. I just keep the teeth on the arms clean, free of rust and dirt. I do use a small amount of dry lube spray on the drive teeth, but not often. Other than that, I keep the slide wipers, and seals clean, also use a little slide seal conditioner on them, to keep them soft. A little baby power on the wipers keeps them sliding easier on the sides. I use ProtectAll on the slide outside walls also, including the windows and frames, to keep them slick.
    While moving large slide in/out, it seems to operate best, with door open, to allow air displacement.
    New trailer is a big step up from your PUP, hope you enjoy it!
    Jerry
