stufarmer's avatar
stufarmer
Slide out lube
I'm looking for the (best...what ever that means), product for inside the Slide Out Channels ? I've maintained the Gear track & Motor Wheels but it's time to do something for the Steel Slide out Channels. I've used Amsoil products for just about everything in the past, and I know they make a grease, but I'd like to ensure I'm using the correct product for the need. Your suggestions please.
  • I have a Lippert Shwintek slide and they say to use PTFE spray. I couldn't find the brand they recommend locally (CRC Power Lube with PTFE) but did find the WD-40 version at the local hardware store.
    http://wd40specialist.com/products/dry-lube/
    There's also a video by a Winnebago tech that demonstrates where/how to apply it.
  • I use dry silicone in a spray can . It can be obtained at most auto parts and hardware stores.
    Grease or oils will collect dirt.
  • Old-Biscuit wrote:
    MFG. typically recommends NO LUBES as they will collect dirt/become abrasive
    I wire brush mine down and then light spray of 'DRY GRAPHITE SPRAY' (goes on wet then dries immediately---does not attract dirt)
    BUT can rub off so DON'T spray on bottom of slide out as it might transfer to flooring
    I've used the product for Slide-outs sold at the RV stores. Also the Metal Prep spray from Amsoil. Just hoping there was something that had a better effect on the Slide sounds.
  • We use slide lube by camco. a dry silicone lubricant that does NOT attract dirt, never would use grease, I don't like cleaning the cake dirt. Been using it on our slides for a couple of seasons with no issues
  • MFG. typically recommends NO LUBES as they will collect dirt/become abrasive
