scott_dv's avatar
scott_dv
Slide out not level
I have a 35' travel trailer with a cable operated slide out. I noticed upon inspection that when looking from the side my slide is not level and siting about 1.5" lower on the back of the trailer vs. the front.
It opens and closes fine, but the previous owner stated they had a leak in the back corner which made me want to investigate further. It seems to seal fine against the top and bottom it's just the back top corner that is sitting lower.
Any ideas? Is there an adjustment that can be made?
  • I have no experience with the bale type (if thats what you have) but the rack and pinion type have a myriad of adjustments. The problem is one adjustment effects another but if you make small incremental changes, it's easily done.
  • SoundGuy wrote:
    Yeah, start with make / model /year of trailer, make of slide mechanism if you can - pics would help as well.
    Its a Bal Accuslide system if it's cable driven. The only adjustment is on the cables, which wont change how it sets in the opening. They only need adjusting if they have slack in them. There are 3 rollers that can be seen from the outside underneath the slide when extended. You might check to see that none of those are broken.
  • 1996 Hornet 35F
    I will post pictures once I get home, can't seem to do it on my phone.
