notsobigjoe's avatar
notsobigjoe
Nomad III
Jan 23, 2021
slide out not sealing
I've had my camper since 2009. I bought it from a bank repo in Massachusetts when I was living in Binghamton NY. It has always had a slide sealing problem. I would always get a little bit of water in the camper through the slide and sometimes a lot. The difference between upstate NY and here in Central Florida is the mold. When it leaks and I'm not up on it the inside of the camper can have mold in many places which I have to clean up. Perhaps it's time to look at a repair for this problem.
The slide goes in and out very easily and has never failed me. It is rock solid but had to be rebuilt a bit when I got it because of the original water damage. The damage was in the rear seat of the booth and was easily fixed. The camper itself when I went to pick it up when I first bough ti was leaning in the sand where the problem is. The frame was bent from this leaning for obviously some time.
No wood and no rot due to aluminum and Styrofoam walls. I'll post some pics of the problem.
Thanks in advance, Joe
See the sag by the front of the compartment door
