Lynnmor wrote:
Try mineral spirits.
That may damage the rubber roof.- LynnmorExplorer II
rexmitchell wrote:
Thank you. Anything special to make getting the old gunk off easier?
Try mineral spirits. - 12th_Man_FanExplorerYou don't have to get all the sticky off just get it good and clean with simple green or something like that and the enernabond will stick just fine with the old sticky still on.
You can use a hair dryer or heat gun to get most of the old tape offf. Just don't get it too hot. - rexmitchellExplorer
byronlj wrote:
Peel it off, CLEAN it, and put a strip of eterna bond back down.
Thank you. Anything special to make getting the old gunk off easier? - byronljExplorerPeel it off, CLEAN it, and put a strip of eterna bond back down.
- LwiddisNavigator“is this an eternabond fix?”
Could be. Could also be regular maintenance. Needs a close inspection and work regardless. If this is a new RV to you, should have noticed issue on pre-purchase inspection.
