Hoffmac wrote:
I have already done these things to it
1. Check the fuses and replaced a blown one
2. Regrounded it
3. I checked for anything blocking it and checked the seam.
This is my first RV and I have limited knowledge. I want to fix it myself due to finances.
I have not hooked the 30 amp back up to a power source yet. I am using a battery to run the slide out.
You mention there being a bad fuse, there could also be a tripped or bad "short stop" breaker. They look
like this link. Normally located under the trailer, near a junction box where the positive battery lead goes into the trailer. Some of them have a reset button, some are auto reset (when battery is disconnected and re-connected), and some (like a fuse) do not reset at all. They are available (in varying amperage's) at most auto part stores.
The bear responded while I was typing. I think we are talking about the same breaker.
