Hoffmac wrote:
The battery is the same one that is in my car. I just use jumper cables when I need to move it in and out and it has worked perfectly fine
ok, good , we can eliminate that , the car is running and giving the battery full power.
If the slide went out and then not back in, then what happened ?
I agree to check the breaker as mentioned .
Once it went dead, did it stay dead or is this an intermittent problem ?
If it's the latter, then i would look at all grounds, motor and switch.
The motors can overheat from the extra drag of the slide if its not adjusted 100% correctly.
