Firefighter4929's avatar
Sep 14, 2018
Slide out won't close
We have our 2014 Primetime Lacrosse 324RST parked on a friends property and have been there for a month. In preparing to leave, we found the bedroom slide out will not retract. It doesn't have a way of manually moving it as the other two slides do. It sounds as if only one of the motors that drives it is operational, yet I can't see how to get at it.
Any suggestions as to how to access it and more importantly what I can do to get the slide out in so we can get home?
  • I bought a used tt with a slide, but got no owners manual in the transaction. The slide works great, but I was concerned with how to get it in when the day comes when it stops working. I removed several pieces of wood trim and panels until I found the hex fitting dadechil mentioned.
  • ScottG wrote:
    bgum wrote:
    Mowingman has it right. You couldn't give me a slide. Nothing but trouble. Had a bedroom slide leak and cost me over $2000 to fix. The living room slide pulled all the 12 volt and 120 volt loose. Nothing but headaches.
    Here we go, always someone that's got to turn a decent conversation into some kind of devisive argument and push their own off beat agenda.
    That's not what this thread is about at all.
    x2
  • I would figure out what slide I have and then find the manual online.
  • generally you have to access the slide motor. most have a removable end plug with a hex fitting put a hex bit in a cordless drill to spin the motor and see if the slide will move
  • Mowingman has it right. You couldn't give me a slide. Nothing but trouble. Had a bedroom slide leak and cost me over $2000 to fix. The living room slide pulled all the 12 volt and 120 volt loose. Nothing but headaches.
  • If the motor runs, and it is a Lippert slide, more than likely the stupid plastic gear that moves the slide is broken. Ours was on a bedroom slide, and the mechanism is under the floor of the bed structure. The underbed storage had a plywood floor that came out with 6 screws, and there was the broken gear, in plain site.
    If you can find the machinery, you can unhook the gear rail and push the slide in by hand.
    If it is an older slide, Lippert does not make any parts, and aftermarket gears are not available. My gear was built by a local machine shop, using the old plastic one as a model.
    good luck.
  • Need to know what kind of slide system. Can you see an aluminum strip of gearing on the sides of the s/o?
    Every s/o has a way to manually close it. Best to find out how before it happens! ;)
