38-72ExplorerJun 22, 2013Slide stops and then starts up againI’ve got a 2003 Artic Fox 5th wheel with a slide problem. The slide goes out just fine. But, when retracting, it will come in about 8 inches or so and then stop. If I let up on the switch f...Show More
sclarkExplorerJun 22, 2013You may have a weak self resetting breaker. I would locate and replace it. Good luck.
Related Contenthydraulic slides stop and startRoom slide out stops and startsGeneral Quietpac 75D Stopped Running, won’t startGenerator start/stop switchWater Heater Leak on start up.
