tomman58ExplorerNov 27, 2014slide won't retractHowdy, Our new Jayco has a problem with the bed room slide it will not move either way. The motor seems to spin but will not connect to slide. Anyone have this problem? TIA
SWDExplorerNov 27, 2014You should be able to crawl underneath remove a panel and use the supplied crank to manually retract the slide.
Related ContentRight rear leveler not retracting fullymanual retraction of slidesSlide won't retract: 2004 Imperial Holiday RamblerSlides won't retract...Adding power outlets in slide with no wiring
