Howdy, Our new Jayco has a problem with the bed room slide it will not move either way. The motor seems to spin but will not connect to slide. Anyone have this problem? TIA
Not familiar with Jayvo slides, but it sounds like you sheared a pin. If so you need to turn the motor till the motor shaft and shaft are aligned then drive out Lord pin and replace. The next thing would be to look for a reason for it to break.
