Howdy, Our new Jayco has a problem with the bed room slide it will not move either way. The motor seems to spin but will not connect to slide. Anyone have this problem? TIA
It is almost always the gears or pins that break on slideouts. The motor seldom quits. You might be able to replace the broken part fairly easy, you might not.
One definite way of retracting is : --- : have someone inside pushing the button to retract (in case a tooth catches somewhere), and get a few guys outside and push push push. Then strap it shut with a ratchet strap and call the dealer for an appointment
