azdryheat wrote:
Most likely a Schwintek system. Plenty of trouble shooting videos on the net. In your case you might try running the slide all the way out then bring it in a foot then back out. Do that 3 or 4 times and it might fix the alignment issue. You might look for the controller and check for an error code.
I don't have my schwintek book with me right now but I'm pretty sure that's what you don't want to do. What you do is run it out all the way and hold the button down an extra 3 or 4 seconds after it stops. Then run it in all the way and hold the button after it stops. You do that every time you run it in or out. Never stop when it is part way in or it.
