scarecrow56's avatar
scarecrow56
Slideout Mechanism
As I look for a new TT I see a few different types of mech. Schwinntech with 2 tracks top and bottom, A cable system and, I believe, the old gear and gear bar under the slide. Any thoughts on which is the good, the bad and the ugly? Thanks
  • I've had good luck with the rack and pinion system. It's easy to adjust and simple to repair.
    Our current rig has the latest Schwintek system (top and botom rails) and seems to be doing great. I did a lot of reasearch before buying an RV with this system and from what I read, the latest incarnation works well. It's hi-tech and Lippert - two terms that dont go well together but it looks like they've finally got something right.
  • I have only had rack and pinion system, but have read about other systems, and seems the gear driven bar type has the least issues/needing less adjustments. However you can get good/bad with most anything.
    Jerry
  • My original gear and bar gearbox just died. Looks like it may cost close to $1000 to get it fixed. Just sayin'.
    BTW I would not select a camper based solely or largely on the slide mechanism. Liveability would be my main criterion.
