Having a problem with our dinette slideout. It is a simple Power Gear twin rack and pinion driven by a single motor. The slide room goes out until the flange on the inside of the slide room hits the...
Thinking about this some more seems the root of the problem is the slider wall flange. You don't list the year model of your TC. Is it possible there is a problem with the seal? Why is the flange flexing? This needs to be replaced or repaired.
