kknowlton
Mar 30, 2014Explorer II
Were you using the slide lock arm(s)? We read that they are to help keep the seals tight on the slides when the slides are not deployed. If you were, then you may need to have the slideout adjusted, or the seals checked/replaced. Good luck!
44,056 PostsLatest Activity: Nov 19, 2013
