Huntindog
Dec 06, 2020Explorer
carringb wrote:That seems like a pretty tall tale.... But then again the inflatable hot tub you use in your TT seems like an even taller taleGdetrailer wrote:
on
Your "comfortable" is most likely not the same "comfortable" for everyone.
There is no way that one single 1200W "fireplace" heater can easily provide enough heat to keep a "home like" temperature of say even 68F anywhere near 32F or below in 400 sq ft space.
I can tell you from experience rebuilding several trailers from 20ft to 26ft (170 sq ft to 221 sq ft) the ABSOLUTE best temp one single 1200W heater was able to get those trailers to was 58F with outside temps at or below 32F. OK for working in, but certainly not "comfortable" to live in. And for the record, neither trailer had slides...
Thanks for the assumptions, but you’re wrong. I keep the trailer at 70 during the day. I do turn it down to 64 at night. Once the trailer is up to temp, the fireplace has zero trouble maintaining the temperature down into the low 20s. I do use the furnace for recovery in the morning, mostly because I like the warm floor. If I kept the fireplace temp steady overnight, the furnace wouldn’t even turn on, but I like lower temps for sleeping
44,072 PostsLatest Activity: Aug 23, 2026
